Shocking...
Shocking...
by Rusty_CallyT » Mon Feb 06, 2006 1:07 am
right, after the hook meet (or rather the drive back from it) i realised just how bad my car is. I have -35mm spax springs and shox and its hard as... well sommit very hard, and as Stu pointed out not only is the camber a mile out the car is bouncing and skipping down the road, its not pleasant, loss of grip and being grabbed by the seatbelt all the time isnt handy.
So what can people recommend for a man on a budget?
Id like to have a 30 or 35mm drop and im planning to throw camber correction bushes and 225/35/18's on with a ET40 offset. So i need sommit hardish but not painful, something that will give enough to keep all 4 wheels on the floor, but not cause too many issues with tyres scrubbing.
Any suggestions? recommendations?
Rusty_CallyT
by jaybv6 » Mon Feb 06, 2006 9:31 am
The only setup I'd use would be koni adjustables with matched eibach springs. However they aren't for someone on a budget. In my experience you get what you pay for. Especially when buying suspenson components
jaybv6
by Dan Willis » Mon Feb 06, 2006 11:05 am
And Adam already knows that [img]/smile.gif[/img]
Jay's right though - I've used that Koni setup twice, and it really is very good.
Dan
by Rusty_CallyT » Mon Feb 06, 2006 2:50 pm
got any links or prices for the koni adjustables and some decent springs?
Rusty_CallyT
by jaybv6 » Mon Feb 06, 2006 3:43 pm
From memory they are about £450 for the kit. Plus fitting of course. The koni kit normally comes with ROC springs but if you can find somewhere that will supply matched Eibachs you are laughing. Best to go for the Cavalier Turbo kit as it comes with fully adjustables all round, the Calibra Turbo kit only comes with the from adjustables.
jaybv6
by dj_smurph » Mon Feb 06, 2006 7:20 pm
i have used koni with the vogtland springs on mine no complaints but i am fwd only means that i could dial out lift off oversteer, also a full koni kit i used on my corsa, got rid of all the nasty faults that vauxhall suspension suffers from
dj_smurph
by Rusty_CallyT » Mon Feb 06, 2006 8:24 pm
well iv spoken to a shop and they recomended a kit:
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->>> Not many options for this car now!
>> Best bet is probably a Koni sports adjustable kit £399.00 including vat<!--QuoteEnd--></div><!--QuoteEEnd-->
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Yes they are top adjustable damping front & rear, should come with Koni springs as it is a Koni sports kit. (Note that Koni, like Bilstein don't make their own springs), SK248.<!--QuoteEnd--></div><!--QuoteEEnd-->
Rusty_CallyT
by Fraz » Mon Feb 06, 2006 10:45 pm
had the Bilstein sprint line ( I think) kit on mine was very good handling but bit hard for some
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Note that Koni, like Bilstein don't make their own springs)<!--QuoteEnd--></div><!--QuoteEEnd-->
if that is so...how come you buy a matched kit for Bilstein
by Cheater2k » Mon Feb 06, 2006 11:43 pm
im useing konis on irmsher springs, very hide ride, but doesnt skip (i do have it wound fully though)
Cheater2k
by Welsh_Andy » Tue Feb 07, 2006 7:13 pm
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->if that is so...how come you buy a matched kit for Bilstein<!--QuoteEnd--></div><!--QuoteEEnd-->
just because they matched doesnt mean they made by same company
edit: just found out H&R make the springs that are packaged with bilstein kits
Welsh_Andy
by jaybv6 » Tue Feb 07, 2006 8:12 pm
indeed, Koni kits use ROC springs. That's why I always specify matched Eibach's with my Koni kits as it give the better setup. ROC are ok though.
jaybv6
by Rusty_CallyT » Tue Feb 07, 2006 8:19 pm
hmm if im gonna do it i may as well do it properly so it looks like im shopping for koni adjustables and eibach springs in a month or 2 lol
Rusty_CallyT
by Welsh_Andy » Tue Feb 07, 2006 9:04 pm
i have the koni kit to,although it came with vogtland springs,beore they changed to ROC. i would have thought the vogtlands are better though
Welsh_Andy
by Toddy » Wed Feb 08, 2006 3:14 pm
Adam, are your shocks OK? Just wondering as mine were shot and the same happened to me (bouncing around at the back end).
Toddy
by Rusty_CallyT » Wed Feb 08, 2006 3:30 pm
they were next to new when i got the car
Rusty_CallyT
