Mystery lead/sensor
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->as for the end could it not be someone has cut pulled the end off and used some sort of heat shrink on the ends?<!--QuoteEnd--></div><!--QuoteEEnd-->
No, 'cos there's a white bit of plastic in the end as well. Unless it was some unused bit of loom that was blanked off in the factory.
dan1w
