Calibra dials
Calibra dials
Hello to all, i have a k reg calibra 4x4 turbo, but i dont have the batt and oil gauges under the head unit (just a blanking pocket instead). Is it possible to fit the dials into my calibra or does there need to be a special connection for them?
EMEZENERTHANU
You can get the guages off ebay...most of the time around £30. They just slot in under the radio cage.
Dunno if all callys had the wiring for them already there, its a black 8 pin connector about 5mm thick by 20 mm length.
You will need to change the oil pressure switch to an oil pressure sender (located behind the oil pump) These are about £75 from VX new. Not sure on the voltmetre if there is any other parts needed.
TonyDTM
