alarm not workin
alarm not workin
by projectcalibra » Sun May 21, 2006 5:26 pm
ok robbiev has pointed me in the direction of <a href="http://www.v6calibra.com/alarm/v6calibra_atas.htm" target="_blank">http://www.v6calibra.com/alarm/v6calibra_atas.htm</a> so thanx for that, only problem is my LED dont even flash. dont no much bout cally electrics, so where are the fuses and connections i shld b looking for?
projectcalibra
by RobbieV » Sun May 21, 2006 5:30 pm
This will tell you where the fuses and relays are to start you off [img]/smile.gif[/img]
<a href="http://www.v6calibra.com/docs/calibra_v6_fuses.htm" target="_blank">http://www.v6calibra.com/docs/calibra_v6_fuses.htm</a>
by projectcalibra » Sun May 21, 2006 5:34 pm
how do i no if a relay works :oops:
projectcalibra
by RobbieV » Sun May 21, 2006 5:38 pm
<!--QuoteBegin-projectcalibra+--><div class='quotetop'>(projectcalibra)</div><div class='quotemain'><!--QuoteEBegin-->how do i no if a relay works :oops:<!--QuoteEnd--></div><!--QuoteEEnd-->
Dunno, but some bright spark will tell you soon [img]/smile.gif[/img]
by projectcalibra » Sun May 21, 2006 6:01 pm
ok cldnt find the relays, but did press the pet button and we now have the led working. basically, it flashes slowly for a few secs, then goes into a crazy flashing mode. locked someone in the car, they move around and alarm dont sound, they unlock it from inside and again, no alarm noise. any ideas?
projectcalibra
by jimbo1979 » Sun May 21, 2006 6:14 pm
Are you supposed to have a key fob for these alarms? Never bothered looking at them in either of my cali's?
Or are they set when you lock the car?
Is there a way to test it?
Thanks
And sorry for jumping on your thread
jimbo1979
by projectcalibra » Sun May 21, 2006 6:18 pm
i dont have a key fob, wish i did tho
projectcalibra
by RobbieV » Sun May 21, 2006 6:20 pm
<!--QuoteBegin-jimbo1979+--><div class='quotetop'>(jimbo1979)</div><div class='quotemain'><!--QuoteEBegin-->Are you supposed to have a key fob for these alarms? Never bothered looking at them in either of my cali's?
Thanks
And sorry for jumping on your thread<!--QuoteEnd--></div><!--QuoteEEnd-->
Calibra's dont come with key fobs for locking and switching the alarm on, thats an aftermarket kit.
For more info look here
by projectcalibra » Sun May 21, 2006 6:22 pm
Fault codes can be read out of the Alarm by shorting pins A and H
where are the pins?
projectcalibra
by RobbieV » Sun May 21, 2006 6:29 pm
<!--QuoteBegin-projectcalibra+--><div class='quotetop'>(projectcalibra)</div><div class='quotemain'><!--QuoteEBegin-->Fault codes can be read out of the Alarm by shorting pins A and H
where are the pins?<!--QuoteEnd--></div><!--QuoteEEnd-->
Use this guide but short out pins A & H with a paperclip or bit of wire [img]/smile.gif[/img]
<a href="http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm" target="_blank">http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm</a>
by projectcalibra » Sun May 21, 2006 6:33 pm
do u just count the flashes on the sensor LED? will it do 1 fault, pause and move on, or how does it work?
projectcalibra
by RobbieV » Sun May 21, 2006 6:51 pm
<!--QuoteBegin-projectcalibra+--><div class='quotetop'>(projectcalibra)</div><div class='quotemain'><!--QuoteEBegin-->do u just count the flashes on the sensor LED? will it do 1 fault, pause and move on, or how does it work?<!--QuoteEnd--></div><!--QuoteEEnd-->
Sorry ive never done the test.
by projectcalibra » Sun May 21, 2006 6:55 pm
ok i get 1 flash, pause, 2 flash, pause, 1 flash, pause, 2 flash........then im pretty sure it went 3 flash, pause, 2 flash, pause... so that points to boot. where do i go from here?
projectcalibra
by projectcalibra » Sun May 21, 2006 7:22 pm
all sorted, nothing wrong with it, just its not set off by the ways we tried, leave bonnet open when u activate it and it goes off
projectcalibra
by RobbieV » Sun May 21, 2006 7:26 pm
<!--QuoteBegin-projectcalibra+--><div class='quotetop'>(projectcalibra)</div><div class='quotemain'><!--QuoteEBegin-->all sorted, nothing wrong with it, just its not set off by the ways we tried, leave bonnet open when u activate it and it goes off<!--QuoteEnd--></div><!--QuoteEEnd-->
Well done for getting there [img]/smile.gif[/img]
Users browsing this forum: Google [Bot] and 25 guests
