uneven suspension
uneven suspension
by vauaidy » Sat May 27, 2006 5:50 pm
changed one of my front shocks for one from the scrappy now my cars uneven i can get 2 fingers between tyre and arch pass side and 3 on drivers side and you can tell visually will it settle down over a couple of days
vauaidy
by mevans » Sat May 27, 2006 6:04 pm
did you get it off a car with the same engine?? sure different engines had different suspensions.
mevans
by vauaidy » Sat May 27, 2006 6:27 pm
aintr got a clue i know it was of mk3 cav or calibra which model i have know idea i took the insert out of the one from the scrappy and put it in my strut /hub with my spring the spring off the other strut was bigger than mine does this mean the shocker could be longer aswell
vauaidy
by Stupink » Sat May 27, 2006 6:52 pm
The if the shock is roughtly the right height it should be the same level as the shock is going to be partially withtracted by the weight of the engine. height issues should be spring related only.
Have you actually moved the car yet? it might just settle when you let the handbrake off and roll it back forth a bit.
The other problem swapping just one, gas v's oil shocks, if ones leaked a bit and not got such high gas pressure it might not "lift" the car so high. do they feel the same "weight" when you try to bounce each corner?
tbh fitting just one shock of "some cav" isnt a good plan, at least fit them in pairs. but you really ought to know if its the right one or not. part numbers on the insert would help there.
by vauaidy » Sat May 27, 2006 7:03 pm
think i should by two new inserts for front to be honest ill give it a few days see if it settles
vauaidy
by Stupink » Sat May 27, 2006 7:11 pm
It wouldnt be a bad idea. buy them from a motor factors and they'll be pretty cheap anyway.
by pas » Sat May 27, 2006 8:24 pm
Shocks or springs should be changed in pair...
pas
