Clicking noise coming from engine
Nearly everytime I close or open the throttle I can hear a clicking sound - I've put it in electrical because it sounds a lot like the two clicks you hear when you turn the ignition on - or an indicator lol.
Will it just be a case of something sticking and needing WD40 or something more sinister? Its one problem after another since I said I might sell it, how does it know?!
ross85
open the bonnet and have a listen around the throttle body area while u rev up and down using the cable. there may be grime causing the throttle body fin to catch on the lower edge. if its that just strip it out and use some degreaser or carb cleaner to remove the grime, and refit. handy enough job. shouldnt take anymore than half an hour. most of the nuts are 10mm and philips head screws on the hose clips if i remember correctly.
johnny_adidas
Just got back from buying some carb cleaner and I think its the indicator flasher. Had a play with the engine on and off and the clicking/ticking doesn't sound that well connected to the revs. I also noticed the ticking from the indicators when you have them on is a lot quieter than normal so will it be a dodgy relay/flasher unit or something? Don't know much in this area
ross85
Nah the indicators flash fine and steady, it's just that instead of making the ticking telltale noise when they're on, they just randomly click while I'm driving. But I took the above relay out to make a note of the part number, put it back in and now its working fine??? :confused: lol. Will be doing just over 100 miles tonight so will have to wait and see if its ok.
ross85
