Central locking stopped working
by skellem » Sun Aug 06, 2006 9:48 pm
Well, it used to work and now it doesn't!
I have checked all the fuses and there doesn't seem to be one for central locking. Is it hidden elsewhere?
Could someone please point me in the right direction as to where to start checking why it doesn't work. Would it be the black box in the footwell or the door motors?
Ta!
skellem
by Twangy » Sun Aug 06, 2006 9:57 pm
Rusty had this problem the other day and another member did aswell so there is a couple of threads knocking about, IIRC it was the motors.
Twangy
by Rusty_CallyT » Sun Aug 06, 2006 10:02 pm
is it even trying to lock?
if not its probably a fuse or the control unit under the engine ECU in the footwell
Rusty_CallyT
by TonyDTM » Sun Aug 06, 2006 10:33 pm
Central locking interface is the bottem unit in the drivers footwell. Last 2 pins at the end facing you as you take it out are negative earth switched. Try a earth wire into either of those and it wil either lock or unlock. If it don't, its kaputt!
TonyDTM
by Rusty_CallyT » Sun Aug 06, 2006 11:50 pm
careful now, iv blown 2 control units in 1 day messing with them! just swap it for a known good one to test it
Rusty_CallyT
by skellem » Mon Aug 07, 2006 7:54 pm
<!--QuoteBegin-Rusty_CallyT+--><div class='quotetop'>(Rusty_CallyT)</div><div class='quotemain'><!--QuoteEBegin-->is it even trying to lock?<!--QuoteEnd--></div><!--QuoteEEnd-->
Well, when I turn the key I hear a slight noise which is either boot or petrol flap solenoid. No doors work though.
I will try the control unit then, I might pop down the scrappy and see if they have a spare one...ta for the comments all.
skellem
by Rusty_CallyT » Mon Aug 07, 2006 8:16 pm
have you tried locking inside the car, if its just the key it might be a microswitch
Rusty_CallyT
by skellem » Mon Aug 07, 2006 9:35 pm
<!--QuoteBegin-Rusty_CallyT+--><div class='quotetop'>(Rusty_CallyT)</div><div class='quotemain'><!--QuoteEBegin-->have you tried locking inside the car, if its just the key it might be a microswitch<!--QuoteEnd--></div><!--QuoteEEnd-->
Yeah, tried that mate, no go :frown:
skellem
by FatLadZ » Mon Aug 07, 2006 10:43 pm
<!--QuoteBegin-skellem+--><div class='quotetop'>(skellem)</div><div class='quotemain'><!--QuoteEBegin-->Is it hidden elsewhere?
Ta!<!--QuoteEnd--></div><!--QuoteEEnd-->
try dropping the fusebox back and theres 2 fuses if i remember right ???
FatLadZ
by Rusty_CallyT » Mon Aug 07, 2006 11:05 pm
Fuse 17. 20A - Central door locking system
Rusty_CallyT
by skellem » Mon Aug 07, 2006 11:20 pm
Ta [img]/wink.gif[/img]
skellem
by Fraz » Mon Aug 07, 2006 11:24 pm
now you do know about this Mr G
<a href="http://www.clubcalibra.net/forum/showthread.php?t=9540" target="_blank">http://www.clubcalibra.net/forum/showthread.php?t=9540</a>
by skellem » Tue Aug 08, 2006 12:16 am
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->now you do know about this Mr G
<a href="http://www.clubcalibra.net/forum/showthread.php?t=9540" target="_blank">http://www.clubcalibra.net/forum/showthread.php?t=9540</a><!--QuoteEnd--></div><!--QuoteEEnd-->
I do remember that post, but I have checked all fuses and they seem to be fine. I wish it was a fuse!
skellem
