Tacometer Problem
Tacometer Problem
by tizerni » Thu Aug 17, 2006 4:39 pm
Hi,
I recently got a new rebuilt enging for my calibra but since its went in the tacometer has started going a bit funny. Ie it is normal sometimes but other times it just jumps about wildly. Has anyone else had this problem? would it be a wiring problem or something wrong with the actual instrument, my initial thoughts are a wire damaged during the engine swap but i have no ideal were to look to trace the fault any advise from anyone would be appreciated??
Thanks
ps are calibra wheel arches bolted on or welded on?
tizerni
by RobbieV » Thu Aug 17, 2006 4:50 pm
Hi, on the back of the speedo is a small black block about 7mm square with 3 metal prongs and held down with 1 screw, that is the voltage regulator, try swapping with another to see if that makes any difference.
Wheel arches ? front or back
by tizerni » Thu Aug 17, 2006 5:01 pm
Will check that and see, didnt want to have to take dash off lol but its really really annoying me!!
Back arches some people have told me welded some people have told me bolt on mine will need replaced soon but wondering if its going to be easy or hard and costly!
tizerni
by RobbieV » Thu Aug 17, 2006 5:08 pm
Rear arches are welded on, look here for replacements [img]/smile.gif[/img]
<a href="http://www.bodyshopwarehouse.co.uk/default.asp?go=8" target="_blank">http://www.bodyshopwarehouse.co.uk/default.asp?go=8</a>
by tizerni » Fri Aug 18, 2006 10:55 am
Thats a pretty good site thanks, has anyone had their rear arches done whats the general cost for this?
tizerni
