HT Leads
HT Leads
by RhinoV6 » Wed Aug 23, 2006 12:58 am
Recently replaced battery ...old one was the wrong rating and died VERY slowly causing much confusion and dark thoughts of how an ....alfa would look on my drive :cool:. During the long confusion period I nearly got some new ht leads but had to backout as am currently running in a new wife and the dreaded ticket was approching.(which it duly failed)
<div align="left">Car is now better than before!!! but would changing the 13yr old HT Leads still be worth a punt, if so any advice would be most helpful.
</div>
RhinoV6
by RobbieV » Wed Aug 23, 2006 1:23 am
It wouldn't hurt to change the leads, give the engine a new spark of life [img]/smile.gif[/img]
And welcome to the club.
by EY » Wed Aug 23, 2006 9:56 am
<!--QuoteBegin-RhinoV6+--><div class='quotetop'>(RhinoV6)</div><div class='quotemain'><!--QuoteEBegin-->am currently running in a new wife<!--QuoteEnd--></div><!--QuoteEEnd-->LOL:icon_mrgr
by T.F.S. » Wed Aug 23, 2006 11:32 am
check resistance of the leads with a multimeter....
i put the values on here or mig a while back
T.F.S.
by RhinoV6 » Wed Aug 23, 2006 8:34 pm
Good idea with the resistance check thing will do, but the back three are going to be a bugger to check. I could get some £20 jobs on ebay and just stick'em in but £20 seems too cheap, has anyone tried a set?
RhinoV6
by cornishtaz » Wed Aug 23, 2006 9:51 pm
Not tried the cheap ones and welcome to the site good to see another V6 nearby. I've got to change mine at some point as the car has a slight stutter underload, unless it's my coil pack breaking down.
cornishtaz
by T.F.S. » Thu Aug 24, 2006 9:01 am
The cheap ones have far higher resistance than an old vaux (BERU) lead
to check ignition strength order a spark tester (£5?) from highpower 01302 834343
if there is any interest i can do a group buy on these...no mechanic should be without one!
T.F.S.
by ashleywood.ash » Sat Sep 02, 2006 11:05 pm
what HT leads would you recomend??? i interested to know.
also any recomendations on spark plugs?
ashleywood.ash
by Rusty_CallyT » Sat Sep 02, 2006 11:38 pm
GM or bosch (normal) plugs and whatever leads you can get, not the cheapest but then no need to throw cash away either bought the beru vx ones last time i had any
Rusty_CallyT
by T.F.S. » Mon Sep 04, 2006 8:43 am
plugs- NGK (allways!)
leads - std good condition BERU or magnecor 2nd best(i have magnecor 2nd hand at £50)
regards, brian
T.F.S.
