oil level 'n' battery voltage gauges wiring help needed
by naz_06 » Thu Sep 07, 2006 7:48 pm
ive recently just bought my calibra 2.0 8v and it came with the gauges below the headunit there not wired up i was wonderin if anyone could sort of help me get them working
thanks
naz_06
by RobbieV » Thu Sep 07, 2006 8:05 pm
Hi and welcome to the club [img]/smile.gif[/img]
by andy1 » Thu Sep 07, 2006 8:09 pm
hi i can only help with the oil one first check to see if you oil sensor has two wire prongs, if not you will have to buy one, the loom from the sensor has two wires in it you might just have to search for the other wire some where around the oil senser.
just beind the dash where the clocks fit there is a plug that will fit on the back of the clocks (they are there some where)
acording to vauxhall the looms on the 8v are the same
andy1
by naz_06 » Fri Sep 08, 2006 7:27 am
thanks ill have a look over the weekend and let you no what a find
thanks for the wiring diagram aswell
naz_06
