oil level 'n' battery voltage gauges wiring help needed
ive recently just bought my calibra 2.0 8v and it came with the gauges below the headunit there not wired up i was wonderin if anyone could sort of help me get them working
thanks
thanks
naz_06
hi i can only help with the oil one first check to see if you oil sensor has two wire prongs, if not you will have to buy one, the loom from the sensor has two wires in it you might just have to search for the other wire some where around the oil senser.
just beind the dash where the clocks fit there is a plug that will fit on the back of the clocks (they are there some where)
acording to vauxhall the looms on the 8v are the same
andy1
