mmmmmm oh and mmmmmmmm
<!--QuoteBegin-Twangy+--><div class='quotetop'>(Twangy)</div><div class='quotemain'><!--QuoteEBegin-->Quote: the only differences where the drive belt on the old engine had round teeth as the cogs did, and one wide fan belt, the new engine had sq teeth and cogs and two fan belts : End Quote.
Apparently thats the only difference.<!--QuoteEnd--></div><!--QuoteEEnd-->
erm no i just rememberd somthing there was one extra breath pipe and it went to a small box on top of the inlet manifold with a electric conection
andy1
<a href="http://www.clubcalibra.net/forum/showthread.php?t=27290&highlight=dash+lights" target="_blank">http://www.clubcalibra.net/forum/showthrea...ght=dash+lights</a> Could have been engine management, has been known for it to flicker on.
<!--QuoteBegin-EY+--><div class='quotetop'>(EY)</div><div class='quotemain'><!--QuoteEBegin--><a href="http://www.clubcalibra.net/forum/showthread.php?t=27290&highlight=dash+lights" target="_blank">http://www.clubcalibra.net/forum/showthrea...ght=dash+lights</a> Could have been engine management, has been known for it to flicker on.<!--QuoteEnd--></div><!--QuoteEEnd--> right you are correct i put my phone on record and taped it to the dash and went for a drive the engine management light did flicker and the engine glitched
now what do i look for
any one
any one
andy1
Management light is normally caused by a broken/faulty sensor. Did it stay on long enough to store a code?
If you can be bothered you could start working your way through them all, cleaning contacts/replacing as you go. Or you could wait for it to break, get the code, and fix it [img]/smile.gif[/img]
<!--QuoteBegin-DeepSnoozer+--><div class='quotetop'>(DeepSnoozer)</div><div class='quotemain'><!--QuoteEBegin-->Paz, the calibras have very week grounds meaning that the negatives also called gnd's might get corroded and cause severla electrical problems like those
I Would sugest attaching a cable from the block of the engine to the chassis, and see if it works<!--QuoteEnd--></div><!--QuoteEEnd--> found a lose earth all sorted now,
thanks every one
thanks every one
andy1
