Fault Codes 31 & 48
Fault Codes 31 & 48
by buzzaldrin » Sat Sep 30, 2006 10:37 am
Hello everyone,
Just done the paperclip test on my car and got fault codes 31 & 48.
48 is low voltage on the battery, which I think does need charging up. However, I don't know what to do about 31.
Recently, the car has been intermittently plagued by the ECU light coming on, at which point the car either loses power or cuts out. Not good, obviously.
If anyone can suggest a remedy for fault 31 I would appreciate it.
Cheers.
buzzaldrin
Doofus
by buzzaldrin » Sat Sep 30, 2006 1:02 pm
D'oh!
Just found out that engine not running will cause fault 31.
With engine running, I get fault 48 before the code light resets and goes back to 12, so I don't know if there are any other faults.
Would fault 48 cause the car to go into limp mode though?
buzzaldrin
by EY » Sat Sep 30, 2006 1:50 pm
Any fault that lasts long enough to store a code will put the ECU into limp mode.[img]/smile.gif[/img]
by buzzaldrin » Sat Sep 30, 2006 2:39 pm
So does that mean by charging up the battery my fault might clear off?
buzzaldrin
by EY » Sat Sep 30, 2006 2:46 pm
Why is the battery low? Has the alternator light been flickering on? Once they start to die it's better to just buy a new one TBH.[img]/smile.gif[/img] Yep, to clear the code disconnect the battery for a bit, or turn the ignition on and off 20 times.
