Front/Rear Washers !!! Driving me insane (MOT Monday)
My windscreen washers (front & back) have stopped working.
The wipers work perfectly (when I flick the stalk to wash the windscreen, the wipers still go 4 times) but there's no water coming out at all. There is no sound from the pump, but the water bottle is full.
Ive put a +12V straight to the "V+" on the motor and it squirts fine. And ive check that the "V-" is earthed....
Ive just changed the Wiper Stalk on the steering wheel but its still the same!
The obvious answer is a fuse, but I have checked every single one and none of them have blown. I've checked the handbook and every fuse is present, and there doesn't seem to be a dedicated one for the washer - just one for the wipers (no.6, 30A).
is this fuse (for wipers) also for the Washers?????
Would some1 maybe be as kind to try pulling FUSE 6 (Wiper fuse) and then trying there washers? pls? (its the later type calibra)
Is there a fuse I don't know about?
Is there a relay that i dont know about?
Its driving me mad. Ive also pulled the plug off the motor. and pulled the washer trigger and there is only a TINY change in voltage goes from 0.00v to 0.03v ???
Pls help me ! MOT on monday, ill have to run a wire and swith into the cockpit otherwise which i dont want to do !!!
Also. is the motor triggered by having 12v applied to it when the switch is pulled or is it triggered by the earth being earthed? if you know what i mean lol
Cheers in advance
Cheers in advance
Calibra_uk
Calibra_uk
if its just for the MOT do a "blue peter job" and get a squeezy bottle full of water inside the car so you can lean out and squirt the windscreen with it, im 99% sure they cant fail you for that, particularly if you take it somewhere where they get you to sit in the car and run it through the motions ...... a bit like shouting BEEP when they ask you to do the horn, it works lol
MJ
LOL thanks
MOT should be ok [img]/smile.gif[/img]
Well ive just discovered that:
Washer front dont work
washer Rear dont work
Electric mirrors left+right dont work
rear demister doesnt work
Heated mirrors dont work !!!!
I must have a serious problem somewhere?
maybe a live wire that feeds them all out or something?
will strip it down tmrw [img]/sad.gif[/img]
Calibra_uk
Right !!! im making progress !!!
From what ive gathered the + side of the motor always has 12v going to it....
When you push the stalk it connects the neg side of motor to earth
When i connect the +v side of the motor straight to the battery, everything works fine, but this way then the washers ARENT fused and will be working even without ignition....
So i still need to know are the washers fused ? do they share fuse6 along with the wipers?
pls some1 next time you get in your car pull fuse6 out and see if the washers also stop working !!!!!!
[img]/smile.gif[/img] [img]/smile.gif[/img]
Calibra_uk
