Alternator fan prob
Alternator fan prob
by sam_p2000 » Thu Oct 12, 2006 9:39 am
Anybody on here know if the motor inside the V6 alternator fan is available...either that or any tips for a substitute? I investigated as when my lights and seats are on im only showing 12.5 volts :eek: think my alternator could be up the chute now!
sam_p2000
by MJ » Thu Oct 12, 2006 10:31 am
how many volts were you expecting? 240?
MJ
by sam_p2000 » Thu Oct 12, 2006 10:47 am
Alternator should give a constant supply of about 14 volts no matter what the load or engine speed as they have a voltage stabaliser in them [img]/rolleyes.gif[/img] ...if mine is dropping down when its under load its obviously on its way out! All i need to know is how to fix or substitute the damn cooling fan motor so the new alternator wont die in the same fashon.
sam_p2000
by MJ » Thu Oct 12, 2006 11:57 am
the seats take a huge drain though, with them off it'll be fine [img]/smile.gif[/img]
MJ
by sam_p2000 » Fri Oct 13, 2006 6:09 pm
True...im getting 13v with just the headlights on so perhaps things arent so bad....how important is that alternator cooling fan? It must have been siezed for a while as there are lots of old leaves in the fan housing. By that i mean should i stop using the car untill its fixed or will it be ok to use till one pops up on e-bay?
sam_p2000
by lammy » Mon Oct 16, 2006 12:44 pm
I'd get it sorted as soon as poss...I know mine will come on for 10 -15 mins to cool the alternator (Just had a new one fitted after mine started to play up, however that was because it had been coated in oil from a leak for two years!)..not having it working will affect the life of the alternator I would immagine, and they ain't cheep. If it packs in you'll need a new alternator and a new fan?...better to be safe thatn sorry.
SE9
by sam_p2000 » Mon Oct 16, 2006 8:34 pm
Managed to get one from Aldershot car salvage for £15 this morning! See what you mean the come on for ages after the car stops...hope i havent done any lasting damage! Anyone needs one too there is another V6 down there with everything on it and a broken cambelt.
sam_p2000
by v6calibra » Tue Oct 17, 2006 7:18 am
in this months tv mag there is a bloke who tells you how to fit a mk2 cav heater blower moter in the altinater cowling
v6calibra
by sam_p2000 » Wed Oct 18, 2006 5:56 pm
Got it...i did wonder about it but mk 2 cavs are rare as rocking horse siht in breakers around here. Its a shame there isnt a standard mass produced motor that would drop back in thats still available out there. I cant be the only one who has had this problem.
sam_p2000
by v6calibra » Wed Oct 18, 2006 6:41 pm
they rekon you can do the same thing with mk3 cav one too
v6calibra
Users browsing this forum: Bing [Bot] and 29 guests
