Head Light
Head Light
by Robs-se » Thu Oct 19, 2006 8:33 pm
Is it me or has anyone else noticed the drivers headlight seems to be weaker than the passenger. I've noticed this on both the cars i've had.
Rob
by RobbieV » Thu Oct 19, 2006 9:14 pm
Ive had three V6's and ive not noticed that.
by baby9bird » Thu Oct 19, 2006 9:33 pm
Same on my husbands laguna.
baby9bird
by Will-Ni » Fri Oct 20, 2006 12:46 am
mine are both the same brightness
Will-Ni
by big_gordy » Fri Oct 20, 2006 1:42 am
0i noticed it on my 16v but not om y v6!
by Animal » Fri Oct 27, 2006 11:52 pm
Mine are both the same too. Both crap!
by adamhome » Wed Nov 29, 2006 3:38 am
Haha, yea mine are both crap too, although passenger side is a lil brighter if you look carefully when you close to a wall....
[img]/biggrin.gif[/img]
adamhome
by ruzhda » Wed Nov 29, 2006 11:17 am
I have same problem, i install 2 relays for both short lights. I use power directly from battery. i have 20-30% better light. Using Phillips Vision Plus Bulbs after and before thism relay mod.
ruzhda
by sam_p2000 » Fri Dec 01, 2006 11:01 pm
mine are both rubbish, you sure its not just the illusion of the headlamp lenses being biased towards the nearside? If you put them on dipped about 6 foot from a wall or garage door you will see what i mean about the beam pattern.
sam_p2000
by tsdinos » Fri Dec 01, 2006 11:06 pm
<!--QuoteBegin-Robs-se+--><div class='quotetop'>(Robs-se)</div><div class='quotemain'><!--QuoteEBegin-->Is it me or has anyone else noticed the drivers headlight seems to be weaker than the passenger. I've noticed this on both the cars i've had.
Rob<!--QuoteEnd--></div><!--QuoteEEnd-->
Its reasonable that the Driver's headlight aims lower than the passenger's so it wont blind oncoming drivers. or it maybe not sealed properly and dirt comes through..or it could be a faulty bulb
tsdinos
