Which Side Repeaters
Hiya's,
I've seen some pictures of a cally with the triangle type side repeaters but does anyone know if the BMW 3 series repeater would/could be made to fit a cally ???
I had bmw smoked repeaters on one of my gte's front bumper and they looked ok but can't remember what the actual back fitting was like (already on car so never had to really check fitting)
Also anyone know the type of fitting most fords have repeater-wise ???
Ciao
Def
Ciao
Def
Defiance
the triangle ones are ford focus [img]/smile.gif[/img]
ive fitted clear side repeaters to my 5 series but likewise cant remember the fittings. You could fit pretty much anything you like so long as you get a section of wiring and the plug with it then just cut off your old side repeater plug and join the loom, and either glue the repeaters on or adapt the wing opening to fit.
MJ
Hiya,
Yeah just found the focus ones (not up on fords so just described the look of them) and i also see they come in different colours off fleabay (smoked/blue/clear etc)
Not having to really mess with repeaters i like you never noted fittings he he
Guess i might get a set of each and see how they look and go from there
Hopefully replacement mirrors and rear lights will be here for the start of next week so may order now and try them while i mess with mirrors etc
Cheers for reply [img]/smile.gif[/img]
Have Fun
Ciao
Def
Have Fun
Ciao
Def
Defiance
