brake bleeding
brake bleeding
by katanddan » Wed Jan 10, 2007 11:58 pm
could some one tell me what order do you bleed brakes after changing all the pipes. thank you.
katanddan
by EY » Thu Jan 11, 2007 12:07 am
Starting furthest away from the master cylinder iirc. So n/s/r o/s/r n/s/f o/s/f [img]/smile.gif[/img]
Can someone confirm, i have been know to talk utter crap [img]/biggrin.gif[/img]
by Stupink » Thu Jan 11, 2007 12:21 am
This one crops up everytime someone asks this question.
I always say do the shortest first as that's what the vauxhall manual says to do with the abs unit, others strongly dissagree and say longest first (as it usually is).
So try one, if that doesnt work, try the other [img]/tongue.gif[/img]
by chip » Thu Jan 11, 2007 12:26 am
I find on cavs/astras/novas/calibras they bleed up really easy no matter what order you do it in.
chip
by katanddan » Thu Jan 11, 2007 1:16 am
thanks 4 that guys ill give it a go.
katanddan
by Rusty_CallyT » Thu Jan 11, 2007 10:47 am
iv always done shortest 1st and had no issues, only problem iv has is the pressure bleed kits not doing the job, the brake pedal 2 man method sorts that tho.
Rusty_CallyT
by wantredtop » Thu Jan 11, 2007 2:39 pm
follow the guide on topbuzz :
<a href="http://www.topbuzz.co.uk/maintenance/bleeding_brakes/bleeding_brakes.pdf" target="_blank">http://www.topbuzz.co.uk/maintenance/bleed...ding_brakes.pdf</a>
wantredtop
