LET the rebuild begin
Engine in the black calibra is now totally stripped, complete mess interanally and nothing from the bottom end is salavageable but I put the blow up to fatigue which isn't bad I suppose for a 100k+ 'hard driven' engine.
Fortinately the head came away unscaved so thats where most of the work has been going. Parts everywhere at the moment, but can no one count to 16 :confused: ....14 of this, 15 of that, nightmare :cuckoo:
Head is currently with the man know only as Gary :icon_mrgr for him to work his magic but should be fully rebuilt by next weekend when I can start concentrating on the rest
Here's what's going in.....
Colsibro bronze guides
Oversize valves, waisted stem on the inlet side and standard on the exhaust for obvious reasons
Steel caps and platforms
Vernier pulleys
Double valve springs
Cams
Infact the only bits being re-used from the head are the followers, nice
Vernier pulleys
Cams
Good to see an update.
Make sure your lifters are nice and flat and not concaved from wear if you're going to re-use them on new cams, else they will promote wear on the cams.
How much is gary charging for the headwork if you dont mind saying, still something on my to do list. are they 1mm oversize?
<!--QuoteBegin-Stupink+--><div class='quotetop'>(Stupink)</div><div class='quotemain'><!--QuoteEBegin-->Good to see an update.
How much is gary charging for the headwork if you dont mind saying, still something on my to do list. are they 1mm oversize?<!--QuoteEnd--></div><!--QuoteEEnd-->
Lifters look to be in good condition, thought about buying the SBD ones but their is no real advantage so a bit of a waste of £150'ish.
Yea, the valves are the SBD 1mm oversize, will PM info about Gary.
dicky
Some new bits starting to turn up for the rest of the engine.
Firstly the Arrow's with ARP's, how gorgeous are these :icon_nod: ! Thank god its only a 4 cylinder engine :icon_mrgr! Don't think i'll be breaking one of these!!
Bearings....
And some SBS head studs with ARP's to hold it all down [img]/smile.gif[/img]
Bearings....
And here's the finished head ..........
Few more bits and I can start putting everything back together
(splinter)My god that looks great ....
Looks like what i have to do next.
How much did you get the rods for ??
The rods were a bargin at £650
Progress has been slow over the last couple of weeks, not helped that im working away at the mo and have very limited time on my hands but need to pull my finger out and start putting things back together :icon_mrgr
Is nice to get back every weekend and have a few new toys to play with though.
Bottom end is progressing, having a few bits powdercoated at the moment which should come back next week.
Will hopefully fit some these babies next weekend using Chips TV guide :icon_mrgr
Next up is a Z20LEH oil pump from the vxr, will need to get the pick up pipe custom made to suit but should flow better than the oe pump and has nice steel internals.
And picked up the crank yesterday, beaded knife edged polished and everything balanced up. Looks a lot nicer than when it went it came out the block :icon_mrgr
Here's the pick up pipe that's gonna need to be modified. Would it be best to use the pick up at the end from this one or from the standard one?
Users browsing this forum: Bing [Bot] and 9 guests
