ABS pump and control unit thingy
heavenly_d3vi1
<!--QuoteBegin-heavenly_d3vi1+--><div class='quotetop'>(heavenly_d3vi1)</div><div class='quotemain'><!--QuoteEBegin-->hmm, id best do some searching around then!<!--QuoteEnd--></div><!--QuoteEEnd-->
look at the one in your turbo...it should have a bosch number on the top, then check the one in your 16v
if they are the same...
T.F.S.
<!--QuoteBegin-heavenly_d3vi1+--><div class='quotetop'>(heavenly_d3vi1)</div><div class='quotemain'><!--QuoteEBegin-->what has the speedo got to do with abs stuff? :S<!--QuoteEnd--></div><!--QuoteEEnd-->
ABS sensors are used to calculate the road speed [img]/smile.gif[/img]
