max oil pressure reading!
by Deanose6 » Fri Jan 26, 2007 3:18 pm
ello guy n gals, my oil pressure gauge all ways shows max reading, could it be the sender unit or wld jus gettin another gauge do it?? the gauge returns to 0 wen the engine turned off?? thanx
Deanose6
by Deanose6 » Fri Jan 26, 2007 3:34 pm
where wld i find the sensor then???
Deanose6
by Deanose6 » Fri Jan 26, 2007 3:38 pm
thanx 4 the reply thats the only fing that aint workin properly!! ill av root around tomoz
Deanose6
by Rusty_CallyT » Fri Jan 26, 2007 4:14 pm
back of the block, cambelt side
Rusty_CallyT
by Cozy » Fri Jan 26, 2007 4:47 pm
<!--QuoteBegin-Rusty_CallyT+--><div class='quotetop'>(Rusty_CallyT)</div><div class='quotemain'><!--QuoteEBegin-->back of the block, cambelt side<!--QuoteEnd--></div><!--QuoteEEnd-->
Yep probably wire has fallen out
have a look here theres a couple of photos so you know what to look for
<a href="http://www.clubcalibra.net/forum/showthread.php?t=26964" target="_blank">http://www.clubcalibra.net/forum/showthread.php?t=26964</a>
Cozy
oil pressure gauge
by Deanose6 » Mon Jan 29, 2007 5:00 pm
ello pps i took of that blue plug as u said and that made no differnce the gauge was still rite round the scale, and returned to 0 wen turned the engine off, now i'm scratchin me head!!
Deanose6
by Cozy » Mon Jan 29, 2007 5:06 pm
<!--QuoteBegin-Deanose6+--><div class='quotetop'>(Deanose6)</div><div class='quotemain'><!--QuoteEBegin-->ello pps i took of that blue plug as u said and that made no differnce the gauge was still rite round the scale, and returned to 0 wen turned the engine off, now i'm scratchin me head!!<!--QuoteEnd--></div><!--QuoteEEnd-->
there are two wires that go into it that blue one and a white one (i think) that goes in just to the side of it, if thats missing then its probably that, if it isn't then the sender is probably fooked,
Cozy
by Rusty_CallyT » Mon Jan 29, 2007 5:15 pm
clean it all up as well as open circuit = max pressure
Rusty_CallyT
by Phantom » Mon Jan 29, 2007 7:00 pm
from those pictures it shows 3 wires, two on one connector which is for the oil pressure switch and a single one which is the sender connection, it's that one you need to look for
Phantom
by cwaigy » Wed Feb 14, 2007 7:43 pm
That's funny as mine has just started doing that. The oil pressure gauge is all the way to maximum and stays there. The engine doesn't even have to be running, I can just have the ignition on and it will do the same so it's definitely an electrical issue!
Mind you I've got some other (and possibly related) gremlins in that my oil level light is permanently on even though the dipsticks showing the level to be okay, and my temperature sensor is reading 80 degrees celcius!
Might all be related somehow if the wires run near each other or together.
Craig
cwaigy
