heated seat help
heated seat help
by andy1 » Mon Jun 04, 2007 7:59 pm
i always presumed that the loom was the same or the wires for the heated seats would be under the carpet some where, even if the seat were not fitted as standed can any one point me in the right direction, and i know i dont need them at the moment, but it would be nice to conect them,
andy1
by Rusty_CallyT » Mon Jun 04, 2007 8:02 pm
lifted both carpet sections back and looked under the soundproofing?
Rusty_CallyT
by andy1 » Mon Jun 04, 2007 8:07 pm
tried that mate
andy1
by blue redtop » Mon Jun 04, 2007 8:37 pm
they are there some where,
all calibra's have them as standard
blue redtop
by andy1 » Mon Jun 04, 2007 10:50 pm
as i did pull back the sound proofing it was wet, not happy about that
andy1
by Rusty_CallyT » Mon Jun 04, 2007 11:50 pm
it'll be the blocked drain on the front of the bulkhead probably
Rusty_CallyT
by L337 calibra » Tue Jun 05, 2007 12:00 am
<!--QuoteBegin-blue redtop+--><div class='quotetop'>(blue redtop)</div><div class='quotemain'><!--QuoteEBegin-->they are there some where,
all calibra's have them as standard<!--QuoteEnd--></div><!--QuoteEEnd-->
Oh no they dont I had to wire them into my old 8v
Afaik the loom that plugs into the seats plugs into somewhere in the drivers footwell up by the ECU
I wired mine straight from the switches cant remember the wire colours thou, easy enough just two wires for each side unless you decide to attatch the earth around the seat area.
Andy
L337 calibra
by andy1 » Tue Jun 05, 2007 10:57 am
would any one know what the plugs look like that plug in to the switch and that go under the seats
andy1
by andy1 » Wed Jun 06, 2007 10:21 pm
ok found the plugs for the switchs just belowe the cd slot, still no sign of the plugs that go in to the seats
andy1
by Robs-se » Wed Jun 06, 2007 11:26 pm
My old SE1 had the wiring. it ran around under the long trim panel and then across the front of the raised ridge under under the carpet below the front of the seats on both sides. think it was a brown wire with a connector on it.
Rob
by andy1 » Sat Jun 09, 2007 6:30 pm
ok all done know,
scrap yard found the two plugs on another one cut a good length on both of them, and wired the two the switch, all working, thank you for the advice
andy1
