Doms (almost) complete tutorial on using relays including di
by dom » Sun Jun 10, 2007 4:17 pm
Well I've spent a couple of hours doing a writeup of the most commonly asked questions on how to wire up and use relays.
Included are relay basics, headlight wiring upgrades, electric window/seat control diagrams and others.
Worth a look if you're a little unsure on how relays work.
<a href="http://www.picbits.co.uk/forums/viewtopic.php?t=43" target="_blank">http://www.picbits.co.uk/forums/viewtopic.php?t=43</a>
Dom
dom
by RobbieV » Sun Jun 10, 2007 4:31 pm
Very handy info thanks [img]/smile.gif[/img]
by dom » Sun Jun 10, 2007 4:44 pm
Aye - will amend that in a minute. I've got a couple of screaming kids in the background so got a bit distracted lmao
All the diagrams for the relays are driven from normal switches - if you plan to drive the relay by electronic means then you'd normally use a transistor anyway and would put a suppresion diode across the coil.
Did you know that using Zener diodes across the coil causes the relay to turn off more quickly while still limiting the voltage spike ? [img]/tongue.gif[/img]
dom
by BazV6er » Sun Jun 10, 2007 5:51 pm
very good dom ,very useful
by EY » Sun Jun 10, 2007 6:04 pm
Nice gen [img]/wink.gif[/img]
