whats this box and wire??? furry yellow
by blue redtop » Fri Jun 15, 2007 7:28 pm
1.
furry yellow wire,its located behind the glove box,could it be passenger air bag,(i haven't got one fitted to the passenger side.
2.
and any one know what the box is for, its got vdo stamped on it loads of wires coming from it, could it be anything to do with the bat and volt dials?.ive ripped the car apart today to hunt for the little connector for the dials with no joy.
3.
how do you tell if the wire will be there for the dials,ive had a quick look at the back of the engine to see if ive got a sender there but the engine is to big to see anything,
cheers your help is greatly appreciated:icon_nod:
blue redtop
by blue redtop » Fri Jun 15, 2007 7:31 pm
blue redtop
by RobbieV » Fri Jun 15, 2007 7:41 pm
No 1 is an airbag connector.
No 2 is the check control box and nothing to do with oil & volt gauges, It performs the check on lights and such.
No 3 best thing is put in your own wires for the gauges.
by andy1 » Fri Jun 15, 2007 7:49 pm
<!--QuoteBegin-blue redtop+--><div class='quotetop'>(blue redtop)</div><div class='quotemain'><!--QuoteEBegin-->1.
2.
3.
cheers your help is greatly appreciated:icon_nod:<!--QuoteEnd--></div><!--QuoteEEnd-->i found the oil&volt wires under the steering wheel dash just to the left of the fuse box , raped in a fury yellow cover
andy1
by blue redtop » Fri Jun 15, 2007 7:50 pm
thanks for clearing that up.
so can i connect a passenger air bag to it and it will work OK?.
blue redtop
by RobbieV » Fri Jun 15, 2007 7:53 pm
<!--QuoteBegin-blue redtop+--><div class='quotetop'>(blue redtop)</div><div class='quotemain'><!--QuoteEBegin-->thanks for clearing that up.
so can i connect a passenger air bag to it and it will work OK?.<!--QuoteEnd--></div><!--QuoteEEnd-->
You could try and see what happens [img]/smile.gif[/img]
by blue redtop » Fri Jun 15, 2007 7:54 pm
<!--QuoteBegin-paz+--><div class='quotetop'>(paz)</div><div class='quotemain'><!--QuoteEBegin-->i found the oil&volt wires under the steering wheel dash just to the left of the fuse box , raped in a fury yellow cover<!--QuoteEnd--></div><!--QuoteEEnd-->
i was just going to pm you and ask that.
all i could find was a loome of wires coming from the glove box side what had all the stuff for the heated seats ect,and from the drivers side was all the wires for the stereo,
when you sat wheel dash do you mean the plastic casing around the steering wheel,
any chance of a pic as my arms are covered in scratches...lol
blue redtop
by andy1 » Fri Jun 15, 2007 7:55 pm
make sure battery is disconected first, other wise you my get 2 black eyes
andy1
by andy1 » Fri Jun 15, 2007 7:56 pm
<!--QuoteBegin-blue redtop+--><div class='quotetop'>(blue redtop)</div><div class='quotemain'><!--QuoteEBegin-->i was just going to pm you and ask that.
any chance of a pic as my arms are covered in scratches...lol<!--QuoteEnd--></div><!--QuoteEEnd-->give me 5
andy1
by blue redtop » Fri Jun 15, 2007 7:59 pm
<!--QuoteBegin-paz+--><div class='quotetop'>(paz)</div><div class='quotemain'><!--QuoteEBegin-->make sure battery is disconected first, other wise you my get 2 black eyes<!--QuoteEnd--></div><!--QuoteEEnd-->
will do.
blue redtop
by MJ » Fri Jun 15, 2007 8:01 pm
<!--QuoteBegin-RobbieV+--><div class='quotetop'>(RobbieV)</div><div class='quotemain'><!--QuoteEBegin-->You could try and see what happens [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
[img]/laugh.gif[/img]
MJ
by andy1 » Fri Jun 15, 2007 8:04 pm
ok it took 6
just behind here
<a href="http://i161.photobucket.com/albums/t224/paz666/IM000591.jpg" target="_blank">http://i161.photobucket.com/albums/t224/paz666/IM000591.jpg</a>
<a href="http://i161.photobucket.com/albums/t224/paz666/IM000590.jpg" target="_blank">http://i161.photobucket.com/albums/t224/paz666/IM000590.jpg</a>
wire with a 4 pin micro plug
andy1
by blue redtop » Fri Jun 15, 2007 8:10 pm
cheers for that,will have a look in a sec.
you've got a furry yellow wire to:)
blue redtop
by andy1 » Fri Jun 15, 2007 8:13 pm
<!--QuoteBegin-blue redtop+--><div class='quotetop'>(blue redtop)</div><div class='quotemain'><!--QuoteEBegin-->cheers for that,will have a look in a sec.
you've got a furry yellow wire to:)<!--QuoteEnd--></div><!--QuoteEEnd-->oh yes, but i was in the scrap yard today and that one did not have the yellow cover
andy1
by blue redtop » Fri Jun 15, 2007 8:24 pm
found this not a very good pic,furry yellow and hard plastic under the yellow stuff,
its a bit stiff,i gave it a little tug and both ends are tight?.
was yours in the hard plastic bit?
blue redtop
Users browsing this forum: No registered users and 43 guests
