V6 Alternator/Battery
by ODreams » Thu Oct 25, 2007 8:12 pm
Hi All
I've just changed my alternator; but when i use the seat heater i still get a faint glow from the battery light - i don't get this when using anything else.
Would this indicate a knackered battery? or is there something else i should be looking at?
cheers
O
ODreams
by cornishtaz » Thu Oct 25, 2007 10:36 pm
I've heard that the wiring from alternator to battery isn't suffient enough to handle the load that is put on the electrical system when high current items are being used.
Can't remember whether it was on this site or VXON
cornishtaz
by ODreams » Fri Oct 26, 2007 6:29 pm
Mine's only just started doing it and i've had the car six years. ???
O
ODreams
by Calibra_Mike » Fri Oct 26, 2007 6:38 pm
Ive just had a problem with my alternator wiring, be worth just checking the condition of the cables as I found with mine the Earthing wire had become brittle and corroded, simple install of new wire and everything was back to normal...
by ODreams » Fri Oct 26, 2007 8:21 pm
Cool - i'll give that a try.
O
ODreams
