hanging plug.....
hanging plug.....
by debairaclijr » Thu Nov 22, 2007 1:04 am
Got a plug and socket hanging down from the nearside front splitter. any ideas? itching to plug it in but not sure if i'm supposed to. Cheers all
debairaclijr
by Calibra_Mike » Thu Nov 22, 2007 1:26 am
I have the same, what calibra do you have, Ive got an 8valver and not sure if its required, think it might be a 16v thing... Or IMO it could be to do with the outside temp sensor for the trip computer, not sure to be honest...
by Fraz » Thu Nov 22, 2007 1:33 pm
outside temp sensor ..at a guess
by Mark1 » Thu Nov 22, 2007 1:46 pm
As Fraz said it's the only thing I can think of that would be hanging down.
by lammy » Thu Nov 22, 2007 2:17 pm
Think its the temp sensor as mentioned. Mines hanging too...tried to tape it down last night cos I couldn't locate the fixing hole..still works though!..it's bl**dy freezing!!
SE9
by tazz666 » Thu Nov 22, 2007 3:11 pm
the fixing hole is in the bumper facing the road hope that helps you out
damian
by debairaclijr » Thu Nov 22, 2007 7:21 pm
Thanks guys, mine is an se5 (8v). Still not sure if I should plug it in or not.
debairaclijr
by debairaclijr » Thu Nov 22, 2007 7:51 pm
Not sure.... I've got a temp gauge on the dash and its getting a reading from somewhere (not that it's ever very accurate)
debairaclijr
by tazz666 » Thu Nov 22, 2007 7:56 pm
if you have one it would be either hanging on the wire or if you feel the bottom of the bumber on the inside you will either feel a sensor sticking up from it or a hole where it should be
by debairaclijr » Thu Nov 22, 2007 8:11 pm
Sorry, should have been clearer. I have a clock/temp temp gauge which is getting a approx accurate reading even with this unplugged...
debairaclijr
by Robs-se » Thu Nov 22, 2007 9:25 pm
Is it not for the headlamp washer system from the older models, my old SE had this and thats what i found out it was for
Rob
by debairaclijr » Thu Nov 22, 2007 10:15 pm
good point, my old xe had them ugly little things. Sounds like the answer to me.
debairaclijr
by Fraz » Thu Nov 22, 2007 10:37 pm
temp sensor is a blue one with two wires..washers is black with 3 wires
by lammy » Fri Nov 23, 2007 11:26 am
The 'plug and socket' thing mentioned sounds like the sensor that should be attached to the inside of the front bumper. I think the little fixing lugs on the sensor have snapped off mine? and thats why its hanging down! It won't fix securely to the locating hole in the bumper withot them.
SE9
by tazz666 » Fri Nov 23, 2007 11:43 am
the sensor isnt dear about £11 from vauxhall , but all the outside temp sensors are all the same from the cali to the vectra,omegas. so you could get one from a scrappie
