Big Brake Issue - Please help
by Gigabite » Sun Dec 23, 2007 7:38 pm
Hi,
I have today changed the front discs and pads on my recently purchased DTM.
I have had a complete nightmare with it all the bolts were seized and when I finished the front I went to pump the pedel and it will not firm up. Just wondering do I need to bleed the breaks and how much is this going to cost me?
Where could I have gone wrong, didnt touch the pipes connected to the caliper. Lossen the lid on brake fluid thingy in the engine bay as per the clubcalibra.com how to guide.
Please help me!!!!
Gigabite
by tazz666 » Sun Dec 23, 2007 7:42 pm
chris mate the pads will need to bed in again mate , were all the pistons free to push back?
by Gigabite » Sun Dec 23, 2007 7:45 pm
The pistons were pretty solid - only just got the pads on. Are you saying if i drive it with it all spongy it will improve?
I had the brake fluid resovior undone for quite a while, well the whole time I was changing ths discs and pads
Gigabite
by tazz666 » Sun Dec 23, 2007 7:51 pm
yes they will improve mate doesnt matter about the cap off all day
by Gigabite » Sun Dec 23, 2007 9:10 pm
I took it out and its seems to have improved, did my brakes at my mates house and on the way home seemed to have a grinding noise coming from the front passinger side. Any ideas to what that could be?
Also when I lock my car with the key and take the key out it unlocks itself anyone ever had this?
And to add to the list my hot air blower in the car has all but stopped working, get a trickle of air but nothing like it should be, any ideas on this one!
Thanks In Advance for all your help.
Gigabite
by baby9bird » Sun Dec 23, 2007 9:29 pm
Check the pollen filter isnt blocked for the hot air blower thing,passenger side under the plastic below the windscreen.
baby9bird
by Allys Cally » Sun Dec 23, 2007 10:12 pm
when you lock the door check to see if the passenger door is locking, you'll see the paddle for locking the door inside moving over to the locked position if it doesn't then it will unlock. mine sticks sometimes as well and the car unlocks it's self.
by Gigabite » Sun Dec 23, 2007 10:13 pm
yeah I think the passenger side is not locking or sticking like you said, how do i fix this?
Gigabite
by Allys Cally » Sun Dec 23, 2007 10:20 pm
i just lock the passenger side before i get out :lol:
by Gigabite » Sun Dec 23, 2007 10:47 pm
Just tried that and worked fine! Thanks
Gigabite
by callyben » Sun Dec 23, 2007 11:41 pm
the central locking was working fine for me. and as for the heater. i did say that the resistor on the blower motor was causing the problem and it only worked on full speed selection.
and as i said on msn. the fluid aint that good as it has been sat for many years. changing the fluid will help things
callyben
by Gigabite » Mon Dec 24, 2007 12:14 am
Thanks ben, not complaining. I purchased the car knowing it was going to be a project
Gigabite
by callyben » Mon Dec 24, 2007 1:35 am
your welcome. lots of people on here are very knowledgeable and will help out any calibra fan.
callyben
by Allys Cally » Mon Dec 24, 2007 10:10 am
Gigabite wrote:Thanks ben, not complaining. I purchased the car knowing it was going to be a project
doesn't matter what car you buy it will always be an ongoing project in some way or another :lol:
by Calibra_Mike » Mon Dec 24, 2007 11:09 am
I would advise changing the brake fluid if the cars been sat around for a while, you might find moiture has gotten in there and that wont help things...
The grinding noise could be the dust cover behind the discs rubbing on the discs, ive had that problem before when ive played around with the brakes, just get the car up in the air, take the wheel off and spin the disc, you'll soon track down where the noise is coming from...
I know how you felt about the seized bolts, you should invest in a blow torch, you can get them pretty cheap, got mine for £9.99 from halfords, will come in handy for any other things you might need to change later on... If you plan on doing any suspension work then GET ONE!!!
Users browsing this forum: No registered users and 54 guests
