flickering oil light
by ecosseM » Tue Jan 08, 2008 7:57 pm
can anyone help... got this new annoyn fault with the car... an intermitent flicering oil light comming on, car has got pressure (got center gauges) and have tried replacement sender unit, with a new connector on it.
ligh comes on alot when i accelerate, goes of when let off gas...
am thinking damaged wire somewhere, but wheres the best place to join new section in??
as the loom works along the outer bulkhead(initialy), or run one new wire from oil sender right up to speedo?
or anyone had this prob b4, and knows whats up?
ecosseM
by ecosseM » Tue Jan 08, 2008 8:23 pm
yeh, pressure gauge seems to be working ok, rev it, it goes up, goes down on idle etc...
silly question, but how can check it if disconecteed? (if it lights up, its earthing somewhere it shouldnt?)
ecosseM
by ecosseM » Tue Jan 08, 2008 8:28 pm
al go along with the somit weird bit!! lol
ecosseM
by fattyfattyboomalatty » Tue Jan 08, 2008 9:04 pm
daft question but does the red light not indicate low oil level aswell as pressure?
by STEVA » Tue Jan 08, 2008 9:16 pm
Check the wire coming off the sender it sounds like the wire is bare somewhere and when you accelerate its earthing out on summit
by ecosseM » Wed Jan 09, 2008 9:22 pm
yeh, thats what am thinking steva.... was thinking of replacing aprox 1 meter of the wire, joining it into the std loom on bulkhead, (cutting old wire at same time (to stop earthing out)
ecosseM
by ecosseM » Wed Jan 09, 2008 9:25 pm
as for the low oil level bit... theres a seperate light for that on the check controle pannel, to warn you of low oil level.... unless its an 8v, they dont have them as far as i know
ecosseM
