Battery / Alternator /Battery warning light
HI
Having trouble with an SE8 16v. Battery warning light comes on when you turn the car off & stays on when you remove the key, .......draing the battery
Start the car and it goes out ..... as it should ????
Any ideas on where to start??
cali-bra
Hello and welcome.
Get the alternator checked, had this happen ov a car in the past and it needed a new one.
^as above...
Could be the alternator or something with the charging circuit... Might also be worht getting the battery checked somewhere like ATS to make sure its still up to the job, sometimes the battery cells break down and stop it from charging up properly...
