hid's gone!
hid's gone!
by paudie » Wed Feb 06, 2008 9:27 pm
hi lads,have my nct sat(irish mot)and both balasts in my hids have failed me=[ have second hand head lights arriving tomorrow night and need to know how to take the hids out and go back to factory lighting!!
paudie
by RobbieV » Wed Feb 06, 2008 9:30 pm
They are just bulbs, disconnect the live wire unplug the HID bulb and replace with normal, then connect live wire to the normal bulb, job done.
by paudie » Wed Feb 06, 2008 9:36 pm
is that it!!what does the silver box for that is located just behind the headlight??is that part of the HID kit?
paudie
by RobbieV » Wed Feb 06, 2008 9:38 pm
paudie wrote:is that it!!what does the silver box for that is located just behind the headlight??is that part of the HID kit?
That's the ballast/ignitor and part of the HID kit, to go back to standard lighting follow my first post. You can remove the rest of the HID kit later.
by paudie » Wed Feb 06, 2008 9:43 pm
thanks man,thats one job out of the way!
paudie
by RobbieV » Wed Feb 06, 2008 9:46 pm
Anytime :)
by paudie » Wed Feb 06, 2008 9:51 pm
Robbie,any idea how to replace a faulty brake switch on the pedal?? or what it looks like??
paudie
by paudie » Wed Feb 06, 2008 10:28 pm
nearly have the kit out,just wondering 2things. 1-i presume the yellow wire is for the headlight bulb but can some one conferm this for me as i wont have the bulb untill tomorrow and 2- theres a black wire that is part of the kit attached to the back of the headlight.i cant get the of the kit out because it looks like the black wire is soldered on.can i just cut this wire off or is it needed for something??
paudie
by DrZux » Thu Feb 07, 2008 12:37 am
my headlight bulb wire is yellow
DrZux
by RobbieV » Thu Feb 07, 2008 5:14 pm
paudie wrote:nearly have the kit out,just wondering 2things. 1-i presume the yellow wire is for the headlight bulb but can some one conferm this for me as i wont have the bulb untill tomorrow and 2- theres a black wire that is part of the kit attached to the back of the headlight.i cant get the of the kit out because it looks like the black wire is soldered on.can i just cut this wire off or is it needed for something??
Yellow wire is live to the bulb, where is the black wire soldered to ?
by paudie » Thu Feb 07, 2008 6:48 pm
just below where the bulb goes in! its part of the kit so i presume i dont need it
paudie
by RobbieV » Thu Feb 07, 2008 6:50 pm
paudie wrote:just below where the bulb goes in! its part of the kit so i presume i dont need it
The black wire should be an earth so just remove the black wire.
by paudie » Sat Feb 16, 2008 2:46 pm
got everything sorted with the head lights,thanks lads! my right hand head light is now higer than left (failed nct,left side fine) how do i adjust the beem down to match the left side??
paudie
by RobbieV » Sat Feb 16, 2008 4:02 pm
paudie wrote:got everything sorted with the head lights,thanks lads! my right hand head light is now higer than left (failed nct,left side fine) how do i adjust the beem down to match the left side??
Use a 13mm spanner on the part marked with a arrow :)
by paudie » Fri Feb 22, 2008 1:38 pm
sound rob!
paudie
