knocking noise from steering
by Robs-se » Tue Mar 04, 2008 12:00 pm
I have a knocking noise when on full lock to the right. Could it be CV joint on the way out, have just recently tightened the rear bolt on wishbone (moved about 30 degrees) or driveshaft problem. Any where else i can look also.
Rob
by Phantom » Thu Mar 06, 2008 1:24 pm
that's usually the cuprit, Cv joint that is
Phantom
