Error Code 93
Error Code 93
by RhinoV6 » Wed Mar 05, 2008 9:42 pm
Long time no post - again
Can someone please help! - error code 93 (hall effect low voltage?)
Having Spent £500 the car has run perfectly for at least 10 days. Then after driving 300 miles in one day I got 200 yrds from my front door and EML followed by engine death.
Turned key she fired and has been perfect again for past 2 days
Question:
Where is the hall effect sensor on the old v6 and is it likely to be the loom, if so which bit?
RhinoV6
by RobbieV » Wed Mar 05, 2008 10:40 pm
Camshaft Angle Sensor (cam sensor) - code 93 and 94 can be listed as HALL EFFECT SENSOR faults but this refers to the CAS sensor as the DIS V6 doesn't have a traditional 'in-distributor Hall sensor). Once again the V6 version of this item appears to be vastly superior in reliability to that found on the 16v (where is it a very common 16v problem). Total cam sensor failures can occur, not often. Always check and clean connector first. Failures can sometimes be linked to recent cam belt replacement activity where sensor must have been 'disturbed'.
Cam sensor (i think) is above the oil dipstick, black lead above number 1 knock sensor.
