boot install
the subs only 300watt and amp 540watt max so i was told 1.5mm is enough. and i've had no problems with it. good clear sound through the sub.
no problem Trev, i appreciate any advice from members. sometimes the guys in the shops don't no their arse from they elbow's
went today and got my mdf for building the sub box, and this is what i ended up building. 6x9's will go at either side, sub will sit in the top and the amp will be fixed to the front in between the 6x9's. still got to give it a rub down to get rid of a couple of rough edges, then it will be the job of getting it carpeted and fitting all the goodies into it
thats the whole idea, so i don't need to go shopping in it either. there's method behind the madness mate
today managed to fit the goodies in just to make sure everthing was working alright, no probs worked fine and oh how i missed hearing the bass in the boot. once again she live's
big gordy if you need a hand mate just give me a shout, i'd be glad to help you out
no............... cold hard cash only
not yet Trev hopefully have it trimmed next weekend, bit financially embarrassed just now
monthly pays a b***h and don't get payed till the 24th
