Fuel range calibration
by cornishtaz » Sun May 11, 2008 10:14 pm
Has anyone got the link or info on how to calibrate your fuel range on the trip computers. As mine reads 130 miles when its in the red deffo not correct even for a V6
cornishtaz
by RobbieV » Sun May 11, 2008 10:20 pm
by cornishtaz » Sun May 11, 2008 10:22 pm
Cheers Rob
cornishtaz
by Fraz » Sun May 11, 2008 10:53 pm
did mine ages ago,,,but you had to put a resistor in the tank sender wire..forget what size it was think it was one ohm...but cant be certain
by splinter » Sun May 11, 2008 10:57 pm
Can you do this on the turbo ??
As since ive done my engine its not right at all.
by RobbieV » Sun May 11, 2008 11:05 pm
Fraz wrote:did mine ages ago,,,but you had to put a resistor in the tank sender wire..forget what size it was think it was one ohm...but cant be certain
120 ohm resistor.
by Fraz » Sun May 11, 2008 11:05 pm
can do it on any of them....but if the chip is not the correct one for the car then the range is always going to be way out
before I go and try the range adjustment I think I would check the chip code first (not you Ian)
IIRC hold both buttons down..turn ignition on should then display the code and on the top along with some other info at the bottom..let go and you get another set of numbers
post that here and will look it up
by cornishtaz » Mon May 12, 2008 6:38 am
Cheers guys might check my code as well
cornishtaz
by cornishtaz » Mon May 12, 2008 8:33 am
Had a read of the info Rob but it's not what I remember, what process is used when using the 120ohm resistor
cornishtaz
