KNOCKING THROUGH STEERING
by DiDi16v » Mon Jun 16, 2008 12:08 pm
Hi everyone, the new cali has a knock, can only be felt through the steering and it only happens after you have changed gear and only with the 1st and 2nd maybe sometimes in 3rd too.
My husband and his friend recently changed the clutch and cant seem to find where the knocking is coming from.
My hubby said the is a suspect amount of movement in the gearstick when you put your foot down in 1st or 2nd gear and could be suspect box mount.
The old clutch was slipping and we have only noticed this with the new clutch in and have only owned the car for around a month now, could this be related to the work done on the clutch.
The car does have shot brakes and shot lower arms, these are getting replaced at the weekend so i guess i will have to get him to have a look.
ANY IDEA'S WELCOME
DiDi16v
by cornishtaz » Mon Jun 16, 2008 12:17 pm
Souds like a worn mount best thing to is complete the work you've got planned and see if its still there.
Did you remove the gearbox when changing the clutch is everything torqued up
cornishtaz
by DiDi16v » Mon Jun 16, 2008 1:00 pm
Yeah box had to come out, 2.0 8v n reg, should have been more clear sorry!, he said everything was done up f.t as far as he can remember but he will re-check the work carried out, i was reading another post on a similar subject, thought it maybe the rack, although you can feel the knock through the steering it does seem to be ofset towards the passenger side of the vehicle if that helps.
DiDi16v
by BazV6er » Mon Jun 16, 2008 5:03 pm
when i had my 16v my rack had slight play in it and that sounded like a knock
by Phil69 » Mon Jun 16, 2008 6:40 pm
Is it a single knock or repeated? Also, if its repetitive, does the speed of the knocking increase with the speed of the car? If so, it'll be a cv joint....most likely an inner if it doesnt happen on full lock cornering.
by vauxaidy » Wed Jun 18, 2008 8:40 pm
gearbox mount needs replacing by the sound of it
vauxaidy
by DiDi16v » Wed Jun 18, 2008 10:13 pm
It is a single knock when ever a gear change has been made, will only knock if you accelerate away hard then change gear, also depends if you release the clutch quickly or slowly, if you change gear and release clutch quick it will give a single knock up through the rack or so it feels like anyway.
DiDi16v
by Phantom » Thu Jun 19, 2008 1:16 pm
rear engine mount by the sound of it
Phantom
by DiDi16v » Fri Jun 27, 2008 9:30 pm
i take it you mean the gearbox mount, is there a way of checking this without taking it off, should it be the rack again is there a way of checking it, there is no movement through the steering what-so-ever, applied pressure to steering wheel top to bottom and side to side, shook the steering from left to right quickly at a stand still no knocking.
What ever this is, the location of the noise seems to be the lower part of the bulkhead.
DiDi16v
by DiDi16v » Fri Jun 27, 2008 10:13 pm
I should have mentioned that the brakes, lower arms, drop links have been replaced so these can be ruled out.
DiDi16v
by DiDi16v » Sat Jun 28, 2008 7:32 pm
Think i may have found the problem, it might be shock related or maybe top mount, whilst stood at the front of the car bouncing the front end i can hear a knocking coming from the osf leg somewhere and if i place my hand on the top of the turret you can feel something is knocking, i checked against the nsf and it did not feel to clever but did not knock.
What are your thoughts on this.
DiDi16v
by kdchorse2 » Sat Jun 28, 2008 7:41 pm
I just had both lower wishbones replaced ...as the front suspension strut sits in a rubber bush pressed into the wiskbone..and speed bumps / holes kill them. Mine started knocking when the rubber started breaking..bottom end of the strut onto wishbone, resulted in a very deep knocking sound from around my feet.
kdchorse2
by DiDi16v » Sat Jun 28, 2008 11:35 pm
Yes i to have just replaced both lower arms (wish bones) so it will defo not be these, thanks for the info.
DiDi16v
by Phantom » Tue Jul 01, 2008 1:48 am
sounds like it's either the suspension leg top mount or the arb drop link
Phantom
by DiDi16v » Fri Jul 04, 2008 4:40 pm
Right i have stiffened up the engine mounts (all of) with tiger seal, the major knock i had has gone.
Still a faint knocking but i think this is the top mounts, should there be a fair amount of play on the inner cv joint on the passenger side, it can be moved up and down and side to side if that makes sense, this cv did run dry of grease as the gaitor had split, is this likely to be diff bearings or knackered cv joint.
DiDi16v
Users browsing this forum: No registered users and 49 guests
