ECU Fault Clearing
ECU Fault Clearing
by Redtops Rule » Thu Sep 25, 2008 6:56 pm
Had a code 73 fault (airflow meter low voltage) bought and fitted a new airflow meter but still having the same problem as before.(erratic idle speed and lots of smoke)
Does anyone know if i need to do something to clear the fault codes?
Also got a code for the throttle position sensor before that and replaced that too.
Driving me crazy!!!!
Redtops Rule
by vinny_69 » Thu Sep 25, 2008 7:00 pm
disconnect the battery for one hour to reset the fault sometimes when you replace the part it doesn't reset itself.
by Redtops Rule » Thu Sep 25, 2008 7:01 pm
Nice one ill give it a try
Cheers mate
Redtops Rule
by Redtops Rule » Thu Sep 25, 2008 8:18 pm
right i did that and it has now cleared the eml light,but it stil has extremely erratic idle speed?any ideas?
Redtops Rule
by vinny_69 » Thu Sep 25, 2008 8:19 pm
sounds like your icv needs a clean bud
by Redtops Rule » Thu Sep 25, 2008 8:26 pm
is that an easy job?i got a haynes so i should be able to find it and remove it easy enough.is there something i should use to clean it?
cheers
Redtops Rule
by vinny_69 » Thu Sep 25, 2008 8:49 pm
by Redtops Rule » Thu Sep 25, 2008 9:20 pm
haha fairplay cheers bud
Redtops Rule
by vinny_69 » Thu Sep 25, 2008 11:38 pm
sorry about that mate work got a bit hectic,hope that helped
