Anyone near me able to run a tech 2 on my cali for cash?
by Richiem » Mon Oct 27, 2008 6:37 pm
Hi guys
Got a 4x4 fault that im trying to source with no joy, and im in need of running a tech 2 on her to source the 4x4 ecu codes.
Vauxhall want £95 for just the test :shock:
Dont think ill be doin that !
Thought someone near by might want to help and get some doe for there time.
Cheers rich
by bodgetastic » Mon Oct 27, 2008 6:45 pm
You can save yourself a bit of money and do it with a paperclip, see section 4.......
fault codes
by Richiem » Mon Oct 27, 2008 6:59 pm
I thought that aswell , but this doesnt work on the later cali!
I always did this test on my older ones..
Ive checked with rich at cav16 and brian at vts and they have comfirmed this is the case..
They both say tech 2 only on the late calis..
by BazV6er » Mon Oct 27, 2008 7:15 pm
it should work mate as it works on my girls v reg vectra (even tho on the vectra things are not as straight foward as it seems lol.
by Richiem » Mon Oct 27, 2008 7:39 pm
Tell me about it!
I need to be able to get to the ecu codes, and it doesnt seem to do it..
There all saying that the tech 2 has the ability to drag out the 4x4 codes, and theres no way off doin it other that this/
I dont really want to give vaux £95 for a ten minute job.
Plus talking to the guy that they told me new all about it, it seems he knows alot less than me..
by Richiem » Mon Oct 27, 2008 8:07 pm
When i checked with vts they said you need to cross pin 8 with j.
This i use to be able to do on my 92 turbo.
When i tried this on my 97 cali, there is no wire goin to pin j.
This is why im told you cannot flash the 4x4 codes up.
by bodgetastic » Mon Oct 27, 2008 8:22 pm
Yea that looks correct. Tech 2 it is then :lol:
by Richiem » Mon Oct 27, 2008 9:07 pm
Ive just seen a pc based tech 2 kit on ebay!(£25)
Anyone used one of these, or know anyone that has?
Wondered if it was worth trying out.
by Phantom » Tue Oct 28, 2008 11:20 pm
I would concurr that on the later models you can't read the 4x4 codes
sorry never heard of a pc based one, does it come with the required cable to connect it
Phantom
by poita » Tue Oct 28, 2008 11:43 pm
from what i knew the tech2 never worked on a calibra, only the tech one/OBD1 scanner.
the tech 2 was only for later model opels/vauxhalls
1995 Orange 16v Ecotec
Mods are coming along nicely
Re: Anyone near me able to run a tech 2 on my cali for cash?
by Ian T » Wed Feb 04, 2009 12:21 am
Did you fix this?
I've got both Tech1 and tech2 and am just the other side of the Dartford Bridge from you. ;)
Ian.
Ian T
by Richiem » Wed Feb 04, 2009 6:10 am
Thanxs ian but ive got this sorted now :mrgreen:
Worth remembering you have them though!!
