have problem help me plzzz :(
by Chipa » Thu Oct 30, 2008 9:46 am
i have same problem...
"Ignition coil" and "Gasoline pump" dont working :(
what is the reason??
c20ne Calibra
Chipa
by Markp » Thu Oct 30, 2008 10:00 am
Try the fuel pump relay for your gasoline pump issue. Has any of your wiring been touched lately that could cause issues to the coil. Maybe see if you can borrow a coil from some one to ensure it's not the coil it's self at fault
Markp
by Stupink » Thu Oct 30, 2008 10:28 am
If the fuel pump relay has gone, there will be no ignition either. so it is likely the cause for both problems.
by Chipa » Thu Oct 30, 2008 11:15 am
I had chacked gasoline pump, and it works
but how can I check ignition coil? - I meen, can I turn on it dirrectly? without relay?!
Chipa
by Chipa » Sat Nov 01, 2008 11:28 pm
i am verify ,relay and his not fault :(
and what another problem ?:(( :idea:
Chipa
by Stupink » Sun Nov 02, 2008 12:21 am
Is there power to the relay? switched live to the relay from ignition goes through the big round loom connector, could be poor connection or worn wiring on the clutch arm or similar?
by Chipa » Sun Nov 02, 2008 6:41 pm
I have 3 worker relay! bat no one working on my car :(
Chipa
Users browsing this forum: Bing [Bot] and 17 guests
