Any ideas?
Any ideas?
the misses keeps moning about the position of the window switches (the fact we both have fecked shoulders) and i was thinking it wouldnt be to hard to reposition em.
So i ask my fellow cally nuts,,,,, where would be the best place to put em?
Yes probably or you could move the standard ones, the lower part of my centre console between the seats is a vectra one. to fit everything I flipped the wiring that runs in front of the seats over and secured it along the bottom of the dash and fitted the switches into the centre console in the area to the right of the radio (by drivers left knee) if you cut accross crease in middle standard switch it takes up less space and can be slotted into a hole cut in this area.
or you can buy the cavvy switches and try to trace the wires for the motors in the doors and connect everything up.
good luck.
good luck.
evilcally
i will have a play around see what i can come up with
