strange noise .....
strange noise .....
by BazV6er » Fri Mar 06, 2009 3:00 pm
Went to one of our mini meets last sunday and it was fine but only just noticed a slight tinny noise when you go over bumps....
ive checked the brakes,wheels,wheel nuts, and it appears to be coming from the drivers side
ive jacked it up and had a good luck but cant seem to find any trace of a tin sound.
anybody had this before?
Re: strange noise .....
by vinny_69 » Fri Mar 06, 2009 3:04 pm
what about the heat shield off your exhaust from the rear bank baz mines a bit loose and sounds like that :)
by Mark1 » Fri Mar 06, 2009 3:08 pm
Could be a stone that has got it's self stuck!
by BazV6er » Fri Mar 06, 2009 5:14 pm
yh i will take a better look tomorrow ..
by v6 steve » Fri Mar 06, 2009 7:28 pm
I had that noise some time ago tryed everthing new arms, drop links, trackrod ends, engine mounts got ma wheels balanced and tracking done but the noise was still there then i remeberd that there was a tin of dei icer under the seat so i chucked it out job done :banging:
Have you checked the heat sheild round the alternator thats the only thing i can think would make a tin noise
by Allys Cally » Fri Mar 06, 2009 7:47 pm
:lol: :lol: tin o de-icer :alright:
by MarkV6 » Fri Mar 06, 2009 7:48 pm
There is a heat shield over the top of the rear exhaust box. That came loose on my old one and was resting on top of the exhaust.
Does it only rattle over bumps or can you make it rattle at a certain engine rpm point with the car stationary??
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by BazV6er » Fri Mar 06, 2009 9:30 pm
i will check tomorrow guys
by BazV6er » Sat Mar 07, 2009 4:09 pm
right ive checked it again today , it doesnt do it when the car is stationary or when yu rev it
only over bumps by the looks of it , i checked everything but no sign of anything
strange :|
by BazV6er » Sun Mar 08, 2009 12:03 am
i forgot to add a short video of the noise (bear in mind when i went round the block the phone was on the seat)
and at a few points you can hear the noise when i went over a manhole cover
by Callyman » Sun Mar 08, 2009 12:14 am
Have a good look around the lower wishbone(take the wheel off).
Check the drop link is ok
Always worth checking the bottom of the coil spring hasnt snapped.
Janes Polo started rattling on bumps, turns out half a coil was jumping around in the spring cup. But didnt effect handling at all.
by BazV6er » Sun Mar 08, 2009 12:15 am
will do mate
by kdchorse2 » Sun Mar 08, 2009 8:03 pm
Try the rear pad retaining springs..
I stood by bumps while my wife drove over them...I had removed all the heat shields and everyting else metal on metal or stuffed it with padding..tracked it down to worn rear pad retaining springs on one side... would never have beleived they could make so much noise...sonded like washers being rattled in a coke tin... Simple test to prove it is drive over bumps at speed you know causes rattle but with left foot on footbrake to partially lock the rear pads..or just replace the retainers.
Wifes cavlier had a deeper rattle when a front coil snapped and loose bit sat in retaining cup... went through the MOT twice with a shorter spring!
kdchorse2
by Mark1 » Sun Mar 08, 2009 9:36 pm
callyman wrote:Janes Polo started rattling on bumps
Have a word with that girl and get her in the right car Andy.
by Callyman » Sun Mar 08, 2009 10:01 pm
A corsa you mean? :assshaking:
