boot install
well nipped into my local auto shop yesterday and picked up 2 rolls of acoustic carpet and some spray glue. so this morning made a start on the carpeting the box, got the front done first
cut out the holes for the 6x9's and then trimed it ready for the top to be done
with the top carpeted and trimmed and the hole cut out for the sub it was time to fit the amp and 6x9's, it was easier fitting them before putting it in the boot
now it was just a case of wiring it all back up and fitting the sub
ok it may not be up there with the likes of fostersice17's install (which is a cracking install) but it's simple and effective. and it just goes to prove if i can do it anybody can
Re: boot install
can i just ask how you bring the main power for the amp into the cab from the engine bay my mate seems adamant that i need to cut the door rubber and bring it in from the top corner of the wing and round the door frame but i think there must be a more attractive looking way to do it
charliep1982
Re: boot install
There is a large Rubber grommet behing the engine bay fuse box. Thats where most of us have done it.
Re: boot install
as andy says there is the rubber gromet just underneath the fuse box, you'll also find it easier taking the glovebox out so you can pull the wire through from the engine bay
Re: boot install
It looks nice but how about those 6x9s? i think that sub is killing them if its shared space?!
Re: boot install
Have you fixed the install into the boot or does it just unplug and lift out if needs be?
Keith1983
Re: boot install
the install can be unplugged and lifted out if need be.
Re: boot install
i never turned it up that loud when the parcel shelf was in place. if i wanted to turn it right up i always removed the shelf.
