Earth lead
Earth lead
by RobbieV » Thu May 21, 2009 5:19 pm
Does anybody know the length of the main earth lead from the battery negative on a V6 ?
Re: Earth lead
by Mark1 » Thu May 21, 2009 5:23 pm
You've got one go and check it.
Re: Earth lead
by RobbieV » Thu May 21, 2009 6:49 pm
Mark1 wrote:You've got one go and check it.
If i could get under the car to check how long it is and where the end is i would :roll:
Re: Earth lead
by chaos » Thu May 21, 2009 9:23 pm
it will end on your starter motor iirc
chaos
Re: Earth lead
by Callyman » Thu May 21, 2009 9:24 pm
chaos wrote:it will end on your starter motor iirc
You sure? :shock:
Re: Earth lead
by chaos » Thu May 21, 2009 9:34 pm
well it did on my last car (veccy)
chaos
Re: Earth lead
by Callyman » Thu May 21, 2009 10:00 pm
chaos wrote:well it did on my last car (veccy)
Think you'll find that was from the + on the battery, but might of had a black insulation around it.
Re: Earth lead
by chaos » Thu May 21, 2009 10:03 pm
Could well be mate, if that is the case then i have no idea, sorry for false info guys :D
chaos
Re: Earth lead
by BazV6er » Wed May 27, 2009 8:48 am
ive tried having a look for the dimensions rob but havent found anything yet online.
Re: Earth lead
by Callyman » Wed May 27, 2009 1:07 pm
BazV6er wrote:ive tried having a look for the dimensions rob but havent found anything yet online.
Prob never will tbh.
Re: Earth lead
by MarkV6 » Wed May 27, 2009 7:47 pm
RobbieV wrote:If i could get under the car to check how long it is and where the end is i would :roll:
It's your lucky day MrV.... :mrgreen:
The main earth bolts to the front of the engine block (big ring terminal - 17mm bolt iirc) and is approximately 37 inches in length give or take a couple... (it's a bit bendy)
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
Re: Earth lead
by RobbieV » Wed May 27, 2009 7:49 pm
Cheers Mark, have got one coming in the post soon to change over :)
Re: Earth lead
by Phantom » Sat May 30, 2009 12:19 pm
that's exactly the job I've had to do on the 16V
Phantom
Users browsing this forum: No registered users and 54 guests
