elec windows
elec windows
hi gang.....i cleaned the motor yesterday and after i had done the electric windows dont work.....any ideas??????
cheers
cheers
J570_BOO
Re: elec windows
well ive found the fuse its situated at number 30 and its 30A but the fuse is fine......
J570_BOO
Re: elec windows
Check also number 12 and if maybe somehow connector under plastic lid that is under handbrake got disconnected or got loose
pas
Re: elec windows
J570_BOO wrote:just used a interior cleaner onto a cloth then wiped it....
Thats why mate they dont like any kind of damp should have just wpied clean
calibraboy42
Re: elec windows
ah right...so any idead how i can sort it out?
ive had the centre consol off and disconnected/reconnected the connections and stil no joy...buth fuses look ok to me...still no windows......
J570_BOO
Re: elec windows
do you hear any sounds in doors when you click on switches? like when window goes all the way up or down and you click it again but it cant turn anymore so you hear sound like "tck"
pas
Re: elec windows
J570_BOO wrote:ah right...so any idead how i can sort it out?
put new fuses back in mate?sometimes they look ok but are fkd
mickey1963
Re: elec windows
right...ive put new fuses in....and the only sound you can hear is the click of the buttons nothing else.....
J570_BOO
Re: elec windows
J570_BOO wrote:right...ive put new fuses in....and the only sound you can hear is the click of the buttons nothing else.....
rae they up or down? and have you tryed to reset them?
mickey1963
Re: elec windows
they are up....and havent a clue how to reset them......yep im useless, sorry...lol
J570_BOO
Re: elec windows
J570_BOO wrote:they are up....and havent a clue how to reset them......yep im useless, sorry...lol
whenever the battery is disconnected or any of the electic window components are removed the electric window controls must be programmed as follows?
close all doors and switch on the ignition
close one of the windows by pressing the relevant switch. press and hold the switch for a further five seconds when windoe is fully closed?try it mate it mite work
mickey1963
