front roll bar size?
Re: front roll bar size?
tazz666, do you have other ebooks from Vauxhall college (except the one about C25XE, X25XE and X30XE)?
U_V6
you do know you have to drop the subframe to change the rear anti roll bar bushs
im changing the front's Fraz but i will look at the rears the weekend unless its p*****g it down or snowing
tazz666 wrote:might have why?
I liked that one about v6... and sure would enjoy others. though I could't find ANY information about other books from Vx college or about itself on google (may be wrong search terms...)
any possibility to share?
U_V6
vinny_69 wrote:im changing the front's Fraz but i will look at the rears the weekend unless its p*****g it down or snowing
well the fronts are the drop links as the ATB is only attached by two mounts to the sub frame and by the drop links to the bottom arms. And you should have the later style bolt on ones so dont matter what size your ATB is as the dont actually go on the ARB just bolt to it
like these
http://cgi.ebay.co.uk/Vauxhall-Calibra- ... 0001r11219
its not the droplinks he wants to change Fraz, its these http://cgi.ebay.co.uk/VAUXHALL-CAVALIER ... 3a41f02886
he says its the fronts not rears, and those are the ones to the subframe
yes he said in his first post that it was the anti rollbar bushes that he wanted to change, so i'm guessing its these hes talking about
thats what I thought as well but he is on about the fronts
even i was confused yes you are both right i want to change the front droplinks and the rear roll bar bushes,i wasnt aware you needed to drop anything to replace the bushes as i thought it would be the same as the veccy
it looks like i might have to investigate the front end clonk a bit better as i thought the front end had roll bar bushes 2
i take it when you say rear bushes you are talking about the ones on the front subframe, the bushes are held on with a metal bracket and bolt not sure if you will get into them with the subframe still on the car, im sure someone will tell us, everytime we'v done them we have been working on the engine so the engine has been out
you wont get the bolt/ metal bracket out with out dropping the subfarme for teh rear ones
Though you could just drop the one side and do it that way
Users browsing this forum: Bing [Bot] and 7 guests
