Panda's SE3
Re: Panda's SE3
by tazz666 » Sun May 23, 2010 8:40 pm
Rob mate a different class of clientel here,lol :D
Re: Panda's SE3
by vinny_69 » Mon May 24, 2010 1:21 pm
well the tracking is all spot on :band: and she was only a tad out 19 mm drivers side and off the scale pass side :oops:
while he was under it he checked all my handy work and just nipped up the lower arms for us,the thing i did do wrong was the top mount nuts, instead of the thinner nut above the plate and the thicker one below it i did it arse about face :oops: that might be the reason its knocking on big bups on the drivers side.or i just forgot to tighten the oooje nut that keeps the shock in place.
Re: Panda's SE3
by Robs-se » Mon May 24, 2010 8:08 pm
Glad your all sorted now mate
Re: Panda's SE3
by vinny_69 » Tue May 25, 2010 11:57 am
even with the knocking it's great to drive around not looking like a nodding dog :lol:
Re: Panda's SE3
by vinny_69 » Tue Jun 01, 2010 4:09 pm
well i had a look the weekend and the only part i havent replaced has bloody failed :evil:
drivers side wheel bearing :banging: as much as i love it i fecking hate it at times
Re: Panda's SE3
by vinny_69 » Mon Jul 05, 2010 2:03 pm
all was fine on saturday i replaced the steering wheel for a 3 spoke veccy one
sunday went for a blast and............ the se3 isnt in good shape i was sitting at the trafficlights went to pull away but never did :( first i thought it was the clutch cable but nope its got full movement my other problem is it now constantly overheats and only runs on 3 pots
so i think the ashtray needs emptying :lol:
Re: Panda's SE3
by Fraz » Mon Jul 05, 2010 4:28 pm
off with its head :D
Re: Panda's SE3
by vinny_69 » Mon Jul 05, 2010 5:29 pm
already ahead of you Fraz blown between 3 and 4 :( and the clutch is a bit wanked
Re: Panda's SE3
by k1nty » Mon Jul 05, 2010 6:53 pm
allways busy arnt you mate.be like a new one when your done.
k1nty
Re: Panda's SE3
by vinny_69 » Mon Jul 05, 2010 7:02 pm
if i ever get done you mean
Re: Panda's SE3
by Fraz » Mon Jul 05, 2010 7:39 pm
its an 8V takes about an hour to get the head off, check for distortion, new head gasket and rebuild ....start it at 10am be all done by lunch time
Re: Panda's SE3
by vinny_69 » Mon Jul 05, 2010 7:43 pm
i know what it is and how to do it Fraz :roll: the head is off it will need a skim (then again even if it didnt it would get one anyway)
as for the clutch hummm maybe i can get one before the weekend :think:
Re: Panda's SE3
by Fraz » Mon Jul 05, 2010 8:03 pm
why would it need a skim???? has it been cooked, Iknow you said it overheats, but to what degree, should only skim a head if it is really needed ...and thats why i said check for distortion, flat edge (metal rule)check at various points over the head using a set of feeler gauges
Re: Panda's SE3
by Fraz » Mon Jul 05, 2010 8:06 pm
tow it to billing we will do it :D
Re: Panda's SE3
by Jamesyboy » Mon Jul 05, 2010 8:43 pm
Fraz wrote:tow it to billing we will do it :D
lmao! :lol: I can quite believe it :D
