new addition to the family!
Re: new addition to the family!
Rob its a grab handel so you dont need to bend your back when pushing it
v6 steve wrote:Rob its a grab handel so you dont need to bend your back when pushing it
Ha ha, if the the rear window came out it would be like a shopping trolley
Robs-se wrote:v6 steve wrote:Rob its a grab handel so you dont need to bend your back when pushing it
think theres more leg room in a shopping trolley
actually steve tina said she wanted the back windows taken out could you make hers into a tigra mini pickup lol
BazV6er wrote:actually steve tina said she wanted the back windows taken out could you make hers into a tigra mini pickup lol
no probs mate just bring it up
v6 steve wrote:BazV6er wrote:actually steve tina said she wanted the back windows taken out could you make hers into a tigra mini pickup lol
Wouldn't that just make it into an ashtray with wheels (runs for cover)
what 2 pins should i bridge to get the fault codes? any help would be good!
Thanks for posting that Fraz, I thought we covered that before.
the body work of the car is earth or you could dig a hole in the ground and stick it in there as its earth too
Gordy, the entire metal body work of the car is earth.
Up to you what part you choose.
in simple terms it means you find a good earth point, you then get a bit of wire and take it from pin 6 to the earth point
it never said bridge pin 6 to the earth pin of the connector
