Fuse 6 (wipers/horn) keeps blowing
As subject. For some reason this fuse keeps blowing, each time being replaced with the correct 30A fuse, but each new one doesn't last very long before blowing again. I don't think it's related to the horn, so will discount that for now - everytime it's happened it's been raining
I assume therefore there's a fault/short circuit in the wiring to the wipers - but where on earth to start looking? I am an electro-phobe you see!
Any advice appreciated. It's a 1990 Cavalier SRI, so I guess identical-ish to a Calibra.
Ben
Ben
BenW
MOT failure - 50p + labour
Mine used to do this.
The wipper motor starts to seize and draw more and more current.
Expect to need a new wiper motor in the next few weeks
leegsi
Thanks Lee. I did try to swap it out for the one in my Kadett (known working) but sadly it's got the wrong connector.
For what it's worth, I've been spending the last couple of hours trying to trace the fault, and it did still blow with the wiper motor disconnected completely
It now seems to blow simply after a few minutes of driving, not just when the wipers or horn are used. Any chance the wiper motor could draw the current even if the wipers aren't being used at that moment?
In fact, the last time it blew, was almost instantly after the engine was started, having first disconnected the horn push - god only knows if this is related, but I'm guessing it's just a coincidence.
I'm very confused!
I'm very confused!
BenW
OK well we've changed the wiper motor, all appeared to be fine last night. Today however the fuse blew again! Have now replaced the wiper stalk - still no luck! Starting to really annoy us now! Does anyone have any suggestions as to what we should try next? All help gratefully received as I think Ben wants his car back!!!!
vicky80
vicky80
