Dash lights
Dash lights
Can someone put a pic up of the lights that should come on when you first put the key in on the 2.0 ecotec? I think i might have one missing
Re: Dash lights
This is what I get up when I turn my ignition on. Hope it helps. What you think you've got missing then?
Re: Dash lights
The hand brake was off when i took my pic.
Re: Dash lights
Re: Dash lights
Cheers, ill double check mine and see if i am missing anything
Re: Dash lights
yep was missing the EML and the battery light... though for a min the guy i bought it from might have taken out the EML to find a faul but the bulb was there just not working so I replaced it and the battery bulb and all lights come on now... new problem though which i've put in a new thread...
Re: Dash lights
funny though cos i thought the battery light had to be on for the charging system to work? and i swear my battery lights not worked since I bought the car a week or so ago... hmmm
Re: Dash lights
does any one telll me what is the mening of 3rd,4th,and 5th light from the lift in above pic
anasib
Re: Dash lights
1. water level in header tank
2. light bulbs working
3. i think is brakes
all these should go out after a couple of secs, apart from the number 2 which goes out once you press the brake pedal
