do i need a bigger battery
got a new battery a 75 i think they said but looks a bit small to me for a V6 and then i saw the 2 arrows flashing! is this because it IS the wrong 1?
Re: do i need a bigger battery
did they go out after you gave the engine a wee rev?
Fraz wrote:did they go out after you gave the engine a wee rev?
Does the battery warning light failure affect the digi dash as well??
I thought it was only the standard dials, where if the bulb fails the alternator won't charge until the engine is revved past 3k.
Thinking as I type, if the digi dash battery warning does fail then it should have the same effect, but Gordy says the two arrows flashed. Isn't that the digi dash battery warning bulb?
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
the two lights are the same as your ignition light on any car, and if you have just started it you may have to give it a wee rev to get the alternator actually sending a charge and get the light out
just went and had a look and its saying...so a 75 Ah one should do
V6 Standard Battery 66Ah rated
they were flashing when i started the car even after i reved the car they still flash and is continuing to keep doing so...
what is a good number for the calibra battery in the sence of cca? the 1 have is about 550 ish
ohhh btw click in the pic its a video of it!!!
if the lights are on it means your not getting a charge...altanator gone, get a metre and see what the voltage is on the battery
Fraz wrote:if the lights are on it means your not getting a charge...altanator gone, get a metre and see what the voltage is on the battery
now you know me and car electrics i know f all about em dont even know how to use one of those meter thingys
put it on 20 Volts put the red lead on plus + side and the black o the earth
One problem fraz i dont have a meter! lol
