mot = fail
mot = fail
well the se9 failed its mot yesterday
it failed the emissions due to a hole in the backbox, lucky enough i'm managing to get a backbox off calibra ray. and also failed due to a fuel leak near the tank, just hoping its a hole in one of the lines and not the pipes on top of the tank.
Re: mot = fail
Hope they're easy fixes for you, particularly the fuel leak.
Re: mot = fail
i'll have a look later and see if i can locate where its leaking
Re: mot = fail
My boy Rob-se9 had to fix a fuel leak and i think he had to drop his tank to get to it, seem to remember he had to replace a chunk of hose.
Re: mot = fail
I had the same problem last year mate
i had to drop the tank and repair the plate
with the flow and return pipes on it as it
was badly corroded.
was badly corroded.
Re: mot = fail
Allys Cally wrote:i'll have a look later and see if i can locate where its leaking
remember i do have a spare 1 in my garage ally!
Re: mot = fail
well jacked the car up and found the leak straight away, luckily its not the top of the tank. the fuel lines corroded where it goes into the rubber pipe that comes out of the top of the tank.
thing is doing the fuel lines was on the list of things to replace this year, was going to be replacing them with plastic lines as well
right wheres my big mate v6 steve
Re: mot = fail
just done my fuel lines today thanks to help from caraigyboy!
Re: mot = fail
dont think we will be lying under the car Ally think we will just lift it up and stand under it my days of lying under cars are over
glad its not the top of the tank but no dout when we do the rest of the pipes it will break then
Re: mot = fail
dont say things like that be positive mate
Re: mot = fail
well thats her mot'd for another year
big thanks to v6 steve for taking my car to get the exhaust fitted while i was working away last week and also for today in getting the fuel lines replaced. cheers mate
Re: mot = fail
your welcome mate but i hope you are going to change your after shave tomorrow
Re: mot = fail
hope you fitted nice red fuel lines big fella
Re: mot = fail
we did, the set i had for the drain so ill need to get an other set again think thats about 4 times iv bought them for the drain and used them i need to do it before billing
Re: mot = fail
v6 steve wrote:your welcome mate but i hope you are going to change your after shave tomorrow
never mind the after shave, hope your getting that mop cut
